Removing the airbag steering wheel on a Mk2 NB
Last post Sun, Mar 11 2012 10:42 by Zimmerframe. 33 replies.
Page 1 of 3 (34 items) 1 2 3 Next >
  • Wed, May 11 2011 22:21
    • Zimmerframe
      Tue, Nov 10 2009
    • South Woodham Ferrers, Essex
    • Posts 474
     There are guides on some forums on how to do this.  I followed a guide on MX5Nutz.  However, it missed some important bits out and the writer also removed the clockspring mechanism too.  Not what I wanted to do.
    So; this is how I did mine.
    The first thing I did was contact my insurer.  I wanted to stay legal, (why wouldnt you?), some insurers may have a problem with you removing the drivers airbag.  Mine, Admiral, were OK but charged me an additional £17.50 for the year.  Other than that, no problem.
    The next thing; the airbag is AN EXPLOSIVE DEVICE!  It could do serious damage to you so treat it with respect and store it safely once you have removed it.  If it goes off, it would also release some nasty chemicals too. The recommendation is to store it with the bag upwards so that if it ever did go off, it would not fly up into the air and the bag would just deploy.
    The boss kit I bought for mine came from a supplier in the US.  It is a Bell Works 75mm unit and is made for the Mk2 and had cutouts that allow for the clockspring to stay in place.  http://miataroadster.com/works_bell/works_bell_steering_wheel_hub_adaptors_tall_75mm/g-62739.aspx
     It comes with a airbag defeat circuit that has a resistor that fools the airbag sensor into thinking that the airbag is still in place.  On the dashboard is an airbag warning light that comes on if there is a fault.  This is an MoT failure if it is active, (though not having an airbag is fine).  Some people just remove the bulb and some fit a 3 Ohm resistor but I wasnt sure if with a fault detected, the passenger airbag would work or not. This is my kit componants and show the boss with shroud, the airbag defeat wire and a connector for a horn button.
    Anyway, on to the job in hand...
    First, make sure that the wheels are facing straight ahead, then disconnect the battery at the negative terminal.  Then go and make a cup of teaSmile.  I left it about 30 minutes.  I also switched on the headlights so as to leave an open circuit to disipate any residual current.  If your audio system has a key code lock, MAKE SURE YOU HAVE THE KEY CODE FIRST otherwise your audio system will not work when you restore power.
    Next undo the two 10mm bolts that retain the airbag.  There is one either side of the airbag on the steering wheel.
    Now, VERY CAREFULLY remove the airbag by gently pulling it forward.  At this point I was wearing a hard hat and face visor: I kid you not.
    There is a large connector on the back of the airbag.  The large yellow one is the main kiddy that can set the thing off.  The connector is held in place by a clip
    Take the connector out of the clip.  There is a retaining clip that stops the connector from coming apart, (they mean business with these things). release the clip and pull the connector apart
    You can now breathe againSmile.  Place the airbag in a safe place, ( you may want to fit it back again at some point in the future) remembering to store it with the bag upwards.
    Looking at the wheel, you will see the airbag connector which you have just disconnected and a smaller red wire with a white oblong connector near to the steering wheel spline.  This is the horn connector
    Disconnect the horn connector.  If you dont, when you come to remove the wheel, you may break it as it is attached to the steering wheel.  It has the same type of connector that is found in some computers.  There is a release tab that you press and hold down and it then just pulls away.
    This shows how the horn circuit is made on the stock steering wheel.  There are paddles either side of the wheel that move in when you push on the airbag/horn.  The red wired horn connector is fitted to one of these paddles which is why you should disconnect it before the wheel is removed.  If you push on the paddle where my finger is showing, you will see how the horn circuit is made.
    You are now ready to remove the steering wheel.  The spline nut is a 21mm self locking nut.  Loosen it a little way but do not fully remove it yet
    Gripping the wheel at a 3 o/clock, 9 o/clock position and  6 o/clock, 12 o/clock position, wiggle it to remove it.  It will be quite tight on the spline so you may need to tap it from behind too.  This is why you dont fully remove the spline nut, it stops the wheel flying off and hitting you in the faceShock
    You should now hopefully have something like this.  This shows the steering wheel removed.  It also shows the airbag connector and the "clockspring" arrangement.
    This has two lugs that cancel the indicators.  They are the white, (out of focus, sorry) plastic lugs.
    As I said at the start, the boss I bought has cutouts so that these lugs can locate properly.
    Before fitting it however, I connected the airbag defeat wire that came with my kit to the airbag connector.  It has two wires that just push in to the connector.
    I also fitted the new horn wire to the socket near to the spline
    Feed the horn wire through the cutouts in the boss so that it is on the inside of the bos and then fit the boss to the spline.  My boss had a "up" arrow to mark the top.
    This shows the boss in place with the airbag defeat circuit taped up for extra security.  The horn wire is on the inside of the boss.
    Refit the spline 21mm nut.  My kit had a crush washer which I fitted between the boss and the nut.  I temporarily fitted the new steering wheel to the boss so that I had something to hold onto when I tightened the nut.
    I removed the steering wheel and then fitted the rubber shroud to the boss.
    Make a final check of the wheel alignment and then fit the new wheel.  Make sure to connect the horn button to the horn wire and then fit the horn in place.
    Finally, start up and check that the airbag warning light goes out.
    Make your self another well earned cuppa then go for a driveBig Smile.
    If the World didn't suck, we'd all fall off!
    1999 1.8i MK2.
    Lightly modded. Some mechanical enhancments and I like red and chrome!
  • Thu, May 12 2011 8:36 In reply to
    • MX-Drew
    • Canvey, Essex
    • Posts 1,071
    Re: Removing the airbag steering wheel on a Mk2 NB
    Zimmerframe:
    Nice write up but one point, I would check the warning light goes out before fitting the wheel and horn push so that if there is a problem it is easy to get to.
    Also when storing an air bag the connector should be shorted out, and remember you can never send an air bag through the post, it is an explosive.
    If it's broken, repair and improve it. If it an't broken, just improve it.
    Mk2.5 1.8 2004 Strato Blue.
    Coldside MP62 supercharger & Air Con & Eibach Lowering Springs (all fitted myself).
    bastienw said "Je reste bouche bée par la NB à compresseur !!!!" Translated "I remain stunned by the compressor NB!!"
  • Thu, Jan 26 2012 0:18 In reply to
    This is a really usefull posting, thanks Zimmerframe. I'm about to change the steering wheel on my 2004 Mk2.5 MX5 and your photographs are really helpful. I've been in touch with Bill at Miata Roadster via your link and ordered the Works Bell hub that you used. It seems like this is the best option as the Momo hub that I originally ordered looks like it will foul on the airbag and horn connections. Shipping from the USA is only 3 to 5 business days for $45 so I should have my Momo Race wheel fitted by next week.
    Many thanks.
    Bruce
  • Thu, Jan 26 2012 7:17 In reply to
    This is one to go in the FAQ's under other or mods?
    Nice wright up with pic'sThumbs up
    http://www.mazda-mender.co.uk/
    The Disclaimer:-...This post is a natural product made from recycled electrons. The slight variations in spelling and grammar enhance its individual character and beauty and in no way are to be considered flaws or defects, the articles/answers/comments are provided for information purposes and they are not intended to substitute informed professional advice, I /or the Mx5 owners club can not personally be held responsible for any damage occurred from following this procedure or any injuries from it. Proceed at your own risk. ******** I is one of those Buccaneer folk******** ;0)
  • Thu, Jan 26 2012 7:52 In reply to
    • shoestring
      Wed, Sep 14 2011
    • Hexham, Northumberland
    • Posts 2,006
     Great write up, and very kind of the poster of the thread to share it with everyone
    One concern, I read through a few threads as I find them interesting and I'm sure I read one about new MoT legistration, In the revamped MoT test which changes some time this year, if a car was originally manufacturered with an airbag then it has to be in place at the time of the MoT, it would no longer be acceptable to change the wheel and disarm the warning light as if it had never been there as this would be a failure point.
    I'm not wanting to poo poo the change of steering wheels or anything and hope someone will be along to tell me I've picked something up wrong. I've actually put one of my friends off the idea of changing his wheel because of this, so if like I say I've picked it up wrong then please correct me so I can get back to him.
    Mk 2.5 Strato Blue 1.8 S-VT Sport 2005
    Member of Old Git's Clan, Member of the Blue Brigade.
    Spes Durat Avorum
  • Thu, Jan 26 2012 8:31 In reply to
    shoestring:
    If a car was originally manufacturered with an airbag then it has to be in place at the time of the MoT, it would no longer be acceptable to change the wheel and disarm the warning light as if it had never been there as this would be a failure point.
    As far as I know that is correct, I've read that somewhere on't net also and I believe the new regulations came in to force on the 1st January. However, when I questioned my local MOT station on this matter, he looked at the paperwork he'd received listing the new reg's and there was nothing in there to that effect. He said the only problem would be if the SRS warning light remained lit. My MOT is due next month so I might take a chance. If there is a problem with it, I can always swop it back for the original which is one of the advantages of using the boss kit that Zimmerframe used.
    I can also recommend Miata Roadster in California who supply the boss kit, theyve been extremely helpful.
  • Thu, Jan 26 2012 8:34 In reply to
    • Zimmerframe
      Tue, Nov 10 2009
    • Posts 474
    shoestring:
    I think your concerns are correct.  I have retained my old steering wheel and airbag assembly.  My MoT is due in August.  I have used the same MoT station for more than 25 years and trust them to be honest.  I plan to ask them a few days before my MoT exactly what the situation is and show them my car.  I'll ask them if I should fit the old wheel back on for the purpose of the MoT.
    I would not disable the warning light.  If you read my write up, I did not do that.  You have asecond airbag on the passenger side, so would want to know if that had a problem.  I fitted a resistor cuircuit across the airbag connector that fools the detection curcuit into thinking that an airbag is still present.  The light comes on for a second or so, then goes out as it should.
    Perhaps someone who carries out MoT's can comment on the new legalities.
    Hope that helps
    1999 1.8i MK2.
  • Thu, Jan 26 2012 8:54 In reply to
    • shoestring
      Wed, Sep 14 2011
    • Posts 2,006
     Zimmerframe & Bruce
    Thanks for the update, I'll get back to my friend (who has a Mk2 but the plastic on the top of the steering is very loose and rotates on the rim) that folk are still changing their wheels for non air bag type, Bruce since you are the first to go for an MoT with such a change would you post or P.M. me if there are any problems or indeed if it's as sweet as a nut. I sometimes worry about something to worry about and it seems to be getting worse as I get older. Thanks for your patience
    Spes Durat Avorum
  • Thu, Jan 26 2012 9:11 In reply to
    • Posts 9,983
    Here's the relevant section from the MOT Testers Manual, I'll happily make this an FAQ, but will add the mot stuff as well
  • Thu, Jan 26 2012 11:33 In reply to
    Thanks for posting that Geoff. Looking at the section from the tester's manual I think that the legislation is open to individual interpretation. "An airbag obviously missing or defective" - sure, if you've got the original steering wheel with a big hole in the middle where the airbag should be, you're going to have an MOT failure but if you've changed the wheel for a nice Momo is the airbag still obviously missing?
    To clarify further, I have just spoken (again!), not half an hour ago, to my local MOT testing station and his viewpoint was that as long as the airbag monitoring system goes through the correct sequence and the SRS warning light extinguishes after 6 seconds (or whatever time it's supposed to be) then there isn't an issue.
    My MOT is due at the end of February, I shall report back then!
  • Thu, Jan 26 2012 13:50 In reply to
    • Posts 9,983
    bruce@bwcam.com:
    Obviously I have no personal interest in this debate, however if the MOT tester knows that the car was fitted with an airbag as standard, he must look at the situation facing him. As far as I can remeber airbags became a requirement in 1999, so a car without an airbag steering wheel built after this date must fail??
  • Thu, Jan 26 2012 15:01 In reply to
    Geoff Walton:
    Like I said in my previous posting - I think it's down to individual interpretation. That's your interpretation of it which differs from the tester at my local MOT station :-)
  • Thu, Jan 26 2012 23:52 In reply to
    • Posts 9,983
    Final comment from me, surely the active words, which are not open to interpretation are in the middle column
    Method of Inspection 1. As far as practicable, check that all airbags
    fitted as original equipment are present and
    not obviously defective.
    2. Turn on the ignition and check the presence
    and operation of any Supplementary
    Restraint System (SRS) malfunction indictor
    lamp(s) (MIL).
    3. Check the presence and condition of any
    seat belt load limiters and/or pretensioners
    fitted as original equipment.
  • Fri, Jan 27 2012 7:31 In reply to
    Geoff Walton:
    lamp(s) (MIL).
    Off topic...
    I was watching a film the other night with the kids,this chap was in it, true blue with a beard, and thought of youWink
    http://www.google.co.uk/imgres?q=smurfs&um=1&hl=en&sa=N&qscrl=1&nord=1&rlz=1T4ADBS_enGB310GB218&biw=1024&bih=570&tbm=isch&tbnid=PpH2shoP7uM9zM:&imgrefurl=http://pisceschick.wordpress.com/2011/01/25/smurfs-village-for-iphone/&docid=McLlL-wQs4CKfM&imgurl=http://a1.phobos.apple.com/us/r1000/010/Purple/c5/9b/ae/mzi.ymvikdoj.jpg&w=512&h=512&ei=9lEiT6KzHYSr0QXbw7jOCg&zoom=1&iact=hc&vpx=252&vpy=143&dur=3900&hovh=225&hovw=225&tx=144&ty=147&sig=105002282249013226956&page=5&tbnh=117&tbnw=117&start=77&ndsp=22&ved=1t:429,r:1,s:77
  • Fri, Jan 27 2012 7:55 In reply to
    • Posts 9,983
    Mazda-mender:
    See the avatar
