Top 20 Things That Go Wrong With the Mx5--NA (MK1) NB (MK2)
Last post Thu, Oct 23 2008 9:02 by Forum Technical. 0 replies.
Page 1 of 1 (1 items)
  • Thu, Oct 23 2008 9:02
    Locked Reply Contact
    Alignment out of whack.
    Perished shift boots
    Rattling HLAs
    Rust in front of the rear wheel arches and rear of sills
    Dodgy HT leads
    Wing mirrors rusting through and falling off
    Leaky clutch slave cylinder
    Squeaking clutch
    Sticking rear brake calipers
    Weak handbrake
    Ticking EVAP purge valve
    CAS 'O' ring leaking
    Wear on the bolsters on leather seats,
    Electric window cables snapping,
    Door lock spring falling off,
    damp boot
    miss fire (needed new leads)
    suspension bushes knackered
    LWSC causing engine death
    Cam cover gasket leaking
