Copy/paste from Word
Last post Fri, Feb 27 2009 14:14 by 01mx5. 23 replies.
Page 1 of 2 (24 items) 1 2 Next >
  • Sat, Feb 21 2009 1:27
    • Posts 11,082
     When I copy and paste from Word 2003 I get this effect
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Rear number plate = 375 x 165mm
    Any ideas, Firefox problem?
  • Sat, Feb 21 2009 1:33 In reply to
    • Posts 11,082
    Re: Copy/paste from Word
     Just done a test, and it's Firefox, IE7 posts ok......not what I wanted to find out really,as I do a lot of copy paste for the tech forums and I do not want to go back to that old clunker of browser
  • Sat, Feb 21 2009 3:26 In reply to
    • HighLift
      Tue, Nov 18 2008
    • Portsmouth
    • Posts 122
    Bizzare font effects for test purposes.
    Paste from OpenOffice to FF3.
    What are you trying to paste?
    dirty BRG '95 1.8. Absolutely Shocks Gaz kit, BRP M45 coldside, MS diyPNP, 320cc's
  • Sat, Feb 21 2009 6:33 In reply to
    • Posts 11,082
     This is an example of a paragraph from a word .doc on my pc, whan you compose it, it looks fine, if you preview it you get all the Word embedded code, which you can't delete.
    Supercharger fitted by Danny Irvine
    Jackson Racing M45 supercharger kit, plus full standalone plug and play ECU (MSPNP). Other bits include:
    • Jackson Racing BBK "Big Boost Kit" crank overlay pulley (gives 10psi)
    • Innovate LC-1 wideband oxygen sensor and controller
    • 4x Denso 330cc injectors with new O rings (swap straight in)
    • Bosch throttle position sensor (bolts onto standard throttle body without modification)
  • Fri, Feb 27 2009 1:33 In reply to
    • 01mx5
      Thu, Jan 8 2009
    • Central Scotland
    • Posts 3,053
    • Committee
      System Developer
     Does the new "Paste from Word" button sort this, by any chance?
    Ramsay Ashby - Website & Forum Administrator
    Green 1991 Limited Edition BBR Turbo
  • Fri, Feb 27 2009 3:36 In reply to
    • Posts 11,082
    1024x768 Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Lets see
  • Fri, Feb 27 2009 3:37 In reply to
    • Posts 11,082
    No! see aboveHuh?
  • Fri, Feb 27 2009 3:51 In reply to
    • Andy
      Thu, Nov 13 2008
    • Cambridge
    • Posts 316
    <hijack>
    But Word is rubbish anyway, and generates incredibly messy html text full of non-standard Microsoft-specific formatting code. That's what you're seeing in the pasted text for some reason.
    Have you tried OpenOffice Writer? I find it works well, includes an excellent pdf export function, and it reads and writes Word format files.
    Best of all it's free.
    </hijack>
    (Runs away from starting flame wars about MS and Word.....)
    Andy
    1990 Mk1 Eunos 1.6, Mariner Blue
    (Previously:
    1996 Mk1 Eunos 1.8 S-Special type II, Montego Blue
    2003 Mk2.5 1.8 S-VT Sport, Supreme Blue)
  • Fri, Feb 27 2009 6:37 In reply to
    • Posts 11,082
    Andy:
    <hijack>
    </hijack>
    Downloading it now
  • Fri, Feb 27 2009 6:53 In reply to
    • Andy
      Thu, Nov 13 2008
    • Cambridge
    • Posts 316
    There are some useful tips here:
    http://www.linuxplanet.com/linuxplanet/tutorials/6506/3/
    http://www.linuxplanet.com/linuxplanet/tutorials/6515/3/
    http://www.linuxplanet.com/linuxplanet/tutorials/6519/3/
    http://www.linuxplanet.com/linuxplanet/tutorials/6532/1/
    http://www.linuxplanet.com/linuxplanet/tutorials/6532/3/
    Most of it is relevant, not specific to Linux.
    There is also a migration guide somewhere on the openoffice support site.
    PM me with your email address if you can't find it and I'll send you a copy.
    Andy
    (Previously:
  • Fri, Feb 27 2009 6:57 In reply to
    • Andy
      Thu, Nov 13 2008
    • Cambridge
    • Posts 316
    <!-- @page { margin: 2cm } P { margin-bottom: 0.21cm } -->
    Test pasting text from OpenOffice Writer.
    Andy
    (Previously:
  • Fri, Feb 27 2009 6:58 In reply to
    • Andy
      Thu, Nov 13 2008
    • Cambridge
    • Posts 316
    Closer but still not perfect :-(
    Andy
    (Previously:
  • Fri, Feb 27 2009 7:07 In reply to
    • Andy
      Thu, Nov 13 2008
    • Cambridge
    • Posts 316
    The html code pasted in appears to have converted one set of '<' and '>' into &amp;&lt; and &amp;&gt; symbols. What's inside this pair gets displayed instead of filtered.
    <p>
    <meta http-equiv="CONTENT-TYPE" content="text/html; charset=utf-8" />
    <title></title>
    <meta name="GENERATOR" content="OpenOffice.org 3.0  (Win32)" />
    <style type="text/css">
        &amp;lt;!--
        --&amp;gt;
        </style>
    </p>
    <p style="margin-bottom: 0cm;">Test pasting text from OpenOffice Writer.</p>
    <p>&nbsp;</p>
    Could this be an error in the html or xml parser within the forum message editor?
    If I copy/paste the same line of text into a simple plain text editor, like a code editor, all I get is the text I entered, none of the formatting stuff gets through. There must be something in the paste function that determines what is pasted, as clearly the result depends on the application into which it is pasted.
    p.s. Forum wizards, please ignore me if I'm talking blx.
    Andy
    (Previously:
  • Fri, Feb 27 2009 7:13 In reply to
    • Andy
      Thu, Nov 13 2008
    • Cambridge
    • Posts 316
    Normal 0 false false false MicrosoftInternetExplorer4 <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Test pasting text from MS Word.
    Andy
    (Previously:
  • Fri, Feb 27 2009 7:16 In reply to
    • Andy
      Thu, Nov 13 2008
    • Cambridge
    • Posts 316
    Same thing happens here, it's just that the side effects are much worse because of all the crap formatting info that Word puts in.
    <p>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <meta name="ProgId" content="Word.Document" />
    <meta name="Generator" content="Microsoft Word 11" />
    <meta name="Originator" content="Microsoft Word 11" />
    <link rel="File-List" href="/C:\DOCUME~1\ANDYCR~1\LOCALS~1\Temp\msohtml1\01\clip_filelist.xml" />
    <!--[if gte mso 9]><xml>
     <w:WordDocument>
      <w:View>Normal</w:View>
      <w:Zoom>0</w:Zoom>
      <w:PunctuationKerning />
      <w:ValidateAgainstSchemas />
      <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
      <w:IgnoreMixedContent>false</w:IgnoreMixedContent>
      <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
      <w:Compatibility>
       <w:BreakWrappedTables />
       <w:SnapToGridInCell />
       <w:WrapTextWithPunct />
       <w:UseAsianBreakRules />
       <w:DontGrowAutofit />
      </w:Compatibility>
      <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
     </w:WordDocument>
    </xml><![endif]--><!--[if gte mso 9]><xml>
     <w:LatentStyles DefLockedState="false" LatentStyleCount="156">
     </w:LatentStyles>
    </xml><![endif]-->
    <style>
    &amp;lt;!--
        margin:0cm;
        font-size:12.0pt;
    @page Section1
    div.Section1
        {page:Section1;}
    --&amp;gt;
    </style>
    <!--[if gte mso 10]>
    <style>
        font-size:10.0pt;
    </style>
    <![endif]--><span style="font-size: 12pt; font-family: 'Times New Roman';">Test pasting text from MS Word.</span></p>
    Again, one pair of '<' '>' markers has been incorrectly converted to &amp;&lt; and &amp;&gt; then everything betwen these is displayed instead of filtered.
    Andy
    (Previously:
