Puncture Repair Mk3
Last post Sat, Mar 31 2012 18:47 by Rich M. 92 replies.
Page 1 of 7 (93 items) 1 2 3 4 5 Next > ... Last »
  • Fri, Dec 9 2011 19:09
    • KEVBD
      Fri, Nov 25 2011
    • Middlewich, Cheshire
    • Posts 37
    Puncture Repair Mk3
    I am new to MX5 ownership and the owners club. Bought my first MX5 a couple of weeks ago and discovered that there is a temporary puncture repair kit instead of a spare wheel. I am interested to hear from anyone who has used the kit, and their views about how straightforward it is. I travel some busy, badly lit A roads early (6 - 6.30am) most mornngs, and in the unfortunate event of a puncture,  was wondering if the repair procedure is as easy as it seems in the manual?
    Many Thanks
    Kev
    Mk 3, Galaxy Grey. A real lolly on a stick!
  • Fri, Dec 9 2011 19:35 In reply to
    • IanH
    • Grampian
    • Posts 682
    • Area Co-ordinator
    Re: Puncture Repair Mk3
    I would use something other than the sealant that comes with the car as this renders the tyre unusable, Slime (linked below) has good results and can be cleaned out of the tyre to repair it, have seen it used effectively on a friends MK3 Z Sport.
    http://www.amazon.co.uk/Slime-60089-Quick-Emergency-Repair/dp/B002ZBWKDC/ref=sr_1_8?ie=UTF8&qid=1323459110&sr=8-8
    Joint Area Coordinator - Grampian
    Galaxy Grey / Tan MK3 2.0 Sport
    MX-5 Scotland
  • Fri, Dec 9 2011 21:21 In reply to
    • marpar
      Mon, Oct 26 2009
    • Sunderland
    • Posts 4,413
    Sealants can only seal a small puncture, no use at all if you hit something causing real damage to the tyre.
    2002,2.5,CRYSTAL BLUE,1.6L..
    Member of The Blue Brigade.
    Member of The Old Gits.
  • Fri, Dec 9 2011 21:38 In reply to
    • Posts 611
     Hi Kev, same situation I found myself in having just bought one also. Check your sealant bottle as it is probably out of date like mine. I bought a large Holts sealant instead. I also bought another alloy and tyre which I keep in the garage as it won't go in the boot easily. Not very convenient I know but I can at least give wife or kids a ring and ask them to bring it to me or take it to her if she's driving. The tyre size isn't the easiest in the world to get either so doing that gives a bit of breathing time whilst fixing the punctured wheel if a tyre has to be ordered.
    2005 MX5 Mk3 Launch Edition
    Velocity Red 2 litre Sport 6 speed LSD 30K miles
  • Sat, Dec 10 2011 10:20 In reply to
    • KEVBD
      Fri, Nov 25 2011
    • Posts 37
     Hi Rich
    Some good advice. I will more than likely do as you suggest - spare wheel in the garage, and check and replace the sealant if necessary.
    Many thanks
    Kev
  • Sat, Dec 10 2011 10:23 In reply to
    • KEVBD
      Fri, Nov 25 2011
    • Posts 37
     Thanks Ian
    I will check out the link and replace the current sealant, with the 'Slime' product
    Many thanks
    Kev
  • Sat, Dec 10 2011 10:26 In reply to
    • KEVBD
      Fri, Nov 25 2011
    • Posts 37
     Thanks Marpar
    Yup, fingers crossed that I don't have a real big one miles from anywhere!
    Thanks again
    Kev
  • Sat, Dec 10 2011 10:28 In reply to
    • patnav
      Thu, Apr 29 2010
    • Woodbridge
    • Posts 7,319
    We have a spare full size wheel and tyre in the boot of our mk3
    a bit of a tight fit, but has got us out of trouble a couple of timesBig Smile
    Flo,a member of the Black Brigade
    Members of the old git clan
  • Sat, Dec 10 2011 10:37 In reply to
    • y0ungn1ck
      Mon, Dec 28 2009
    • Baldock, Herts
    • Posts 1,118
    Total disaster - when I badly damaged a low profile tyre and wheel on my original mk3, I had to be brought back 100 miles on the back of recovery waggon.  A spare wheel in the garage would not have helped as my wife and I were on holiday!
    One of several reasons that led me to rapidly trade the Mk3 for, ultimately, the Mk2.5 which I now drive and which at least has a spacesaver.
    2004 Razor Blue 1.8 Arctic
    2001 Steel Blue 1.7 Ford Puma
    2008 Colorado Red 2.0 Fiesta ST
    Non Compos Mentis
  • Sat, Dec 10 2011 10:40 In reply to
    • y0ungn1ck
      Mon, Dec 28 2009
    • Baldock, Herts
    • Posts 1,118
    patnav:
    My Mk3 was a 2.0 Sport with 17" wheels and no way could you get a full size spare in the boot, I tried that without success.
    Non Compos Mentis
  • Sat, Dec 10 2011 10:55 In reply to
    • Posts 611
     Yup, times move on and I get the distinct impression we're not expected to change wheels at the roadside these days. I'd be very careful in partic on a motorway and am not sure if it's actually illegal, a passing copper could insist you called a breakdown service if he felt you were in danger I think. That said I can only remember 4 in 40 years which I changed myself and none I called for help with. My son's done his own twice now as he has trouble keeping to the black stuff and I've told my daughter not to even try, not that she doesn't understand how but she would struggle with what can be quite a physical job. We all have breakdown cover and wouldn't hesitate to call them.
  • Sat, Dec 10 2011 10:58 In reply to
    • Posts 611
    y0ungn1ck:
    Mine too, I made a half hearted pass at it then realised I'd have to let it down to try some more. I think it might go in flat then you'd use the supplied compressor to blow it up before fitting.
  • Sat, Dec 10 2011 17:41 In reply to
    • VO5Jo
      Sat, Mar 27 2010
    • SWM - mid Wales twig
    • Posts 2,762
    Nick
    So, when you have a puncture and you're on holiday .... where do you put the full size punctured tyre on wheel?
    Waving not drowning to ALL MKs regardless of 1,2 or 3 ~ Un Mx-5s pour l'année ~ non seulement pour l'été!!
    mk3 1.8 o/p Eibached with Racing Beat backbox- K&N panel filter-WiM'd-Zunsport Grille - Uniroyal Rainsport 2s or Avon Ice Touring ST.
    & ~ affiliated.
    Membre de la Brigade Bleu et en liaison avec Les Noire. Old Git's Clan Yoof Team
    mx5life.com A socially engaging discussion forum all about the Mazda MX-5, Mazda Miata and Eunos Roadster
  • Sat, Dec 10 2011 17:48 In reply to
    • Posts 3,327
    VO5Jo:
    Nick
    On Mrs Eunos`s lap of course! derrrWink Lol!
    Dr. EunosGeek
    Mk 1 Eunos V Special 1.8 1994 with all the right things done to make it go and stop and go around corners better than most. see http://www.mx5oc.co.uk/forum/forums/t/42529.aspx
    Organiser of annual `Nurburgring on a Budget` trip for MX5/Eunos only. Also `Lightning McQueen` replica just for a giggle :) http://www.mx5oc.co.uk/forum/forums/t/37709.aspx
  • Sat, Dec 10 2011 18:05 In reply to
    • Posts 611
    VO5Jo:
    Nick
    Hi Jo,
    This thread and your steel wheels have given me a cunning plan for the 17" brigade. The steels are 16" and with a normal tyre will just fit in the boot according to patnav.
    What size/width rim is it and what size tyres do they have as standard? Could we get smaller tyres (how small can we go?) for a steel wheel then spray the thing yellow Shock and use it as a space saver?
    I'm fairly sure the damaged full size wheel will go in deflated otherwise it's back on the navigator's lap as Taff says Rolling eyes
