Is this damaged? [picture]
The Geographer
Fri, Sep 16 2011
- Bristol
- Posts 118
I just received my clutch kit, and obviously there is something wrong with it.. The spiggot bearing is a bit scratched and slightly dented it. It moves well, I wonder if I should send it back and ask for an exchange, or it's fine. Maybe someone here can help?
2002 MK2.5 1.8i - car - sorry for my English :I
taff eunos
- Riviera, South Wales
- Posts 3,327
Re: Is this damaged? [picture]
No it`s fine, fit and forget about the dent
Dr. Eunos
Mk 1 Eunos V Special 1.8 1994 with all the right things done to make it go and stop and go around corners better than most. see http://www.mx5oc.co.uk/forum/forums/t/42529.aspx Member of The Glorious Green Gang Organiser of annual `Nurburgring on a Budget` trip for MX5/Eunos only. Also `Lightning McQueen` replica just for a giggle :) http://www.mx5oc.co.uk/forum/forums/t/37709.aspx Disclaimer
alan yates
Sat, Dec 13 2008
- thornton
- Posts 950
I would send it back these bearing are usually sealed for life (lubrication is held in the bearing) so IMO the dent is an opertunity for the grease to escape, dry up and you will have a noise bearing don't forget the bearing is going to get hot and the seal in the bearing may just be damaged. I would not put it in the car and then find it was noisey later all that work for nothing
宮古市. 2010 3.5 mx5 1.8 Miyako Velocity Red Mica #39;I&# 宮古市. 2003 Mk2.5 sport in splash green gone but not forgotten. Thornton Nr Blackpool Lancs. You have the right to remain silent. Anything you say will be misqouted, then used against you.
Pollyanna
- Northallerton, North Yorkshire
- Posts 3,187
Bearings need to be perfect when you use them, as said you can't see what damage has been done inside the sealed bearing. You would be surprised what a small piece of grit can do to a bearing once it is under load, I know I used to work for a bearing company.
Geoff Walton
- Posts 9,983
The bearing needs to be perfect, as Polly says a small bit of grit can stuff it very quickly. This one is in a really hard to get to place so you need it to be right first time
Mazda-mender
- Pie land/NW
- Posts 5,610
Geoff Walton:This one is in a really hard to get to place so you need it to be right first time
Agreed
Better safe than sorry.
http://www.mazda-mender.co.uk/ The Disclaimer:-...This post is a natural product made from recycled electrons. The slight variations in spelling and grammar enhance its individual character and beauty and in no way are to be considered flaws or defects, the articles/answers/comments are provided for information purposes and they are not intended to substitute informed professional advice, I /or the Mx5 owners club can not personally be held responsible for any damage occurred from following this procedure or any injuries from it. Proceed at your own risk. ******** I is one of those Buccaneer folk******** ;0)
taff eunos
- Posts 3,327
That bearing is fine and will perform just as well as a `perfect looking` one and last just as long, I would be quite happy to use it as it will cause you no problem. Sorry guys but the above answers are all wrong (apart from mine) and whilst well meaning are mis-guided and show a basic lack of engineering nous. fit and forget
Dr. Eunos
Mazda-mender
- Pie land/NW
- Posts 5,610
Personally i would send it back for a replacement ,you have paid for an A1 part and you have not got it,regardless of where it is going to be fitted, it might last the roadster out as taff as said? but do you want to take that chance? piece of mind and value for money springs to mind.
Do it once and job done ,because it will always be on the back of your mind if fitted.
Geoff Walton
- Posts 9,983
taff eunos:That bearing is fine and will perform just as well as a `perfect looking` one and last just as long, I would be quite happy to use it as it will cause you no problem. Sorry guys but the above answers are all wrong (apart from mine) and whilst well meaning are mis-guided and show a basic lack of engineering nous. fit and forgetDr. Eunos
The bearing "May" be fine and perform "Just as well" as a new bearing, but then again it may well not. Would you want to pull the gearbox again for a £2 bearing? I wouldn't. Do it once do it right
The Geographer
Fri, Sep 16 2011
- Bristol
- Posts 118
Thanks all for the replies! As my spiggot bearing seems to have failed after 49k miles, I might be a bit oversensitive on the subject. I dropped them an email with a picture and they instantly sent me a replacement. Although It may not have been neccessary I will be less stressed about it now.
Thanks all again for the views!
Rich M
- Notts
- Posts 611
I bet many go in like that and are fine and at first sight it does just look like a small dent on the dustshield.
When we look closer though it's actually quite badly distorted, raised above the inner race and below it in parts, so I'd reject it as it may leak grease, let dust in, or squeak if the shield is rubbing on the inner race instead of in its groove.
2005 MX5 Mk3 Launch Edition Velocity Red 2 litre Sport 6 speed LSD 30K miles
alan yates
Sat, Dec 13 2008
- thornton
- Posts 950
For New bearing 4
Against new bearing 1
Who needs a lie down now not so big now are you oh forgot your a Dr as if I would believe a doctor !!!!!!
Underdog
taff eunos
- Posts 3,327
Ho Ho underdog indeed Lol! Funny that, I dont feel like an underdog, more like a fully trained and qualified aero technician with 30 years hands-on motorsport engineering experience. There is no reason to reject that bearing, if any of you do think it is not good for purpose then am afraid it is you that has the problem, not me
Dr. Eunos
Mazda-mender
- Pie land/NW
- Posts 5,610
taff eunos: if any of you do think it is not good for purpose then am afraid it is you that has the problem, not me
Taff if that turned up for me to fit to an owners roadster i would reject it, as they would be paying for an A1 part and that is not, so if that makes me wrong ,than i am glad to be wrong with my standards,
alan yates
Sat, Dec 13 2008
- thornton
- Posts 950
How do you get that helmet over you head ! do you think you are the only one with engineering skills there are others on this site with experience I would rather take than read your experience to have been in the motor vehicle repair industry but for just a few more years than you, You certainly dont have people skills I still stand with fit new which looks like its going to happen underdog
