A long (ish) pause when cold.
Last post Wed, Feb 1 2012 21:58 by Glenboy. 21 replies.
Page 1 of 2 (22 items) 1 2 Next >
  • Mon, Jan 30 2012 20:49
    • Glenboy
      Sun, Jan 29 2012
    • Sawbridgeworth, Herts
    • Posts 78
    As my signature states I drive a 1990 Auto.
    When cold it can, on occasion pause... I'm not explaining this well... I stop at a t-junction to turn left. Car idles perfectly well and normally. I accelerate to pull onto the road... Nothing happens, engine continues to build and then the car will jerk forward with a little wheel spin. Like I say, only when cold and it makes the first couple of minutes of driving slightly interesting. Gear changes can be very jerky but I figure thats the mk1 auto gear change.
    Any ideas what could be causing the lag?
    Mk1 1990 BRG Automatic.
  • Mon, Jan 30 2012 21:50 In reply to
    • Posts 3,327
    Re: A long (ish) pause when cold.
    There are a few things which may be causing the `lag` and jerky gear changes such as sticky hydraulic valves, glazing on the brake bands within the gearbox or tired old over-heated transmission fluid.
    The good news is that all of these things can very often be easily cured by draining the old transmission fluid, flushing out all the tarnish and sludge build upand re-filling with fresh automatic transmission fluid (ATF of the correct grade) along with a dosage of the correct `Wynns automatic transmission treatment`
    Should end up as good as new without lifting a spanner (apart from draining out the old crud)
    Let us know how you get on with it?
    Dr. EunosGeek
    Mk 1 Eunos V Special 1.8 1994 with all the right things done to make it go and stop and go around corners better than most. see http://www.mx5oc.co.uk/forum/forums/t/42529.aspx
    Organiser of annual `Nurburgring on a Budget` trip for MX5/Eunos only. Also `Lightning McQueen` replica just for a giggle :) http://www.mx5oc.co.uk/forum/forums/t/37709.aspx
  • Mon, Jan 30 2012 21:59 In reply to
    • Glenboy
      Sun, Jan 29 2012
    • Posts 78
    Thanks for the quick response. :)
    You are dealing with a techie idiot so bear with me.
    I thought if I drained the transmission fluid I then had to fit a new gasket? Or is this job even easier than that. :)
  • Mon, Jan 30 2012 22:32 In reply to
    • Posts 3,327
    Normally auto-boxes have an oil sump with a drain plug, just drain out the fluid and replace the fluid and ATF treatment down the oversise gearbox dipstick tube, you need to be careful not to overfill, that can be just as bad as underfilling. Follow the workshop manual (available from Muppet as PDF here on the forum.....probably)
    You may need to flush it a couple of times to ensure you have nice clean fresh fluid in the torque converterThumbs up
    Good luck, hope it cures your ills....
    Dr. EunosGeek
  • Mon, Jan 30 2012 22:48 In reply to
    • Glenboy
      Sun, Jan 29 2012
    • Posts 78
    Ok then.
    And for my next really dense question....
    Is the atf dipstick the one on the drivers side of the engine or the one on the passenger side? I have one with a yellow top and a very long dipstick which is on the passenger side ... I initially thought this was it due to the length more than anything but now on reflection I'm not sure. Apologies for my complete lack of knowledge. :)
  • Mon, Jan 30 2012 22:52 In reply to
    • Posts 3,327
    It will be the longer one as it needs to reach down into the gearbox fullyThumbs up
  • Mon, Jan 30 2012 23:04 In reply to
    • Glenboy
      Sun, Jan 29 2012
    • Posts 78
    Awesome. Cheers buddy Thumbs up
  • Tue, Jan 31 2012 15:09 In reply to
    • Glenboy
      Sun, Jan 29 2012
    • Posts 78
    ok... I checked the oil... it was pinkish and didn't smell. So having a look at the past advice on an oil change I chose to leave it. Added some wynns transmission treatment as the reading from the dip stick was straight in the middle. Seems to have smoothed out the gear changes already!
    Thanks for your help Mr/Dr Eunos :)
  • Tue, Jan 31 2012 15:43 In reply to
     The roadster Auto does not have a drain plug, it is a real messy pian in the a*** to do.
    http://www.mazda-mender.co.uk/
    The Disclaimer:-...This post is a natural product made from recycled electrons. The slight variations in spelling and grammar enhance its individual character and beauty and in no way are to be considered flaws or defects, the articles/answers/comments are provided for information purposes and they are not intended to substitute informed professional advice, I /or the Mx5 owners club can not personally be held responsible for any damage occurred from following this procedure or any injuries from it. Proceed at your own risk. ******** I is one of those Buccaneer folk******** ;0)
  • Tue, Jan 31 2012 15:59 In reply to
    • Posts 3,327
    Suck it out of the dipstick hole instead with a large syringe and some poly tubing? Don't know
  • Tue, Jan 31 2012 16:22 In reply to
    • Glenboy
      Sun, Jan 29 2012
    • Posts 78
    Exactly what I planned to do. I have a syphon kit for engines.... But as I said, The oil looked fine and had no smell atached to it either. So I'm thinking shes just knocking on a bit and needs the extra tlc from wynns. Course it could be poor quality atf as well but there isn't anyway of telling that. Maybe when it gets warmer I will change it depending on how long the wynns treatment works. :)
  • Tue, Jan 31 2012 17:33 In reply to
    • Posts 3,327
    Good, and really glad it has sorted you out, worth getting the old oil drained and flushing and adding the Wynns it really makes a huge difference to jerky and hesitant auto-boxes, I found out years ago after borrowing a Volvo estate to tow one of my old Rallycross cars 500miles to Lydden Hill and back and literally `cooked` the auto transmission fluid causing the shift valves to stick solid, ten mins after the Wynns it was all perfect again:
  • Tue, Jan 31 2012 17:51 In reply to
    • Glenboy
      Sun, Jan 29 2012
    • Posts 78
    Ain't seen one of those volvos for a long time :)
  • Tue, Jan 31 2012 18:17 In reply to
    • teaser56
      Fri, Sep 9 2011
    • Posts 165
    Love the volvo - great old cars. could be recognised form a mile away as a Volvo-not like todays Eurobox variants from all the makers.(Sorry to go off topic) I was a keen Rallycross fan in those days and before - The era of Tony Bardy, Gollop and Shankerand there was a Greek driver in an Audi Quatro? - My friend raced a Mini at the time ,I remember a 911 porsche burning out at RAF lynham -very sad. We used to visit John Cross at his Rally cross shop -Autocross.
    terry2003 1.8 vvt, 6speed, lsd - splash green - with K&N air filter- leather gaiter and handbrake. All stock otherwise.....want a stainless exhaust and a wheel refurb
    Harley Road king Classic (2001)
    BMW 318 touring (2005)
    PRS -Tremonti SE
    South central
  • Wed, Feb 1 2012 12:09 In reply to
    • mal jones
      Wed, Sep 21 2011
    • malvern
    • Posts 2,210
    teaser56:
    DIMI MAVAROPOLAS ???? perhapes.
    1991 mark 1 EUNOS 1598 auto in red with black hardtop.(only for the winter) Style bars.
    Area south west midlands.
    Member of the RED DIVISION
    I have changed my cam belt and water pump club.
    2006 C4 from new
