Polish in my Mohair Roof!
Last post Tue, Apr 24 2012 17:27 by msb. 7 replies.
Page 1 of 1 (8 items)
  • Sun, Apr 22 2012 19:24
    • BRGUK
      Sun, Nov 23 2008
    • Manchester
    • Posts 80
    Well as usual damage has been done to my car but not by me!  This sort of thing seems to happen a lot. Either the car gets hit whist parked or someone drives into you. Or vandalised etc etc.
    This time though I got my car back after it being repaired by a reputable garage only to find that when they have been machine polishing it they managed to get polish on the mohair roof.  Does anyone have any idea how I can remove it please?
    I presume garages etc just do this sort of thing all the time and I must be the only person who gives a sh*t or notices!
    Thanks in advance
    Simon Taylor
    1997 MX5 1.6 (Once a Monza)
    1979 MG Midget
    1985 Sinclair C5
  • Sun, Apr 22 2012 19:34 In reply to
    • vidov0
      Sat, Jan 30 2010
    • Teignmouth,Devon
    • Posts 75
    Re: Polish in my Mohair Roof!
    Hi Simon
    You could try using a nail type brush and water to see if that will remove it. If not than the cleaner that comes with the Autoglym roof reproofing kit should do the job. You may need to do the whole roof to prevent a difference in colour and then reproof so 2 jobs done at the same time.Hope this helps.
    Cheers.
    Ian & Kim Oakey
    MX5 1998 1.8 mk2
    Bronze Mica Metallic
  • Sun, Apr 22 2012 19:41 In reply to
    • Posts 4,479
    Raymond at `Jack Smith Trimmers` recommends hot water and Fairy Liquid for cleaning the Mohair roofs he makes, if you are planning to use a nail brush on it, try to work only in the direction of the weave to avoid `fluffing-up` the cloth, rinse very thoroughly and re-proof once fully dryThumbs up
  • Sun, Apr 22 2012 22:02 In reply to
    • Richardn
    • Posts 2,551
     complain in writing to the body shop. The petroleum distillates in the polish rot the hood
  • Sun, Apr 22 2012 22:33 In reply to
    • BRGUK
      Sun, Nov 23 2008
    • Manchester
    • Posts 80
    I cant take it back again, been a bit of an ongoing saga with this one.
    Simon Taylor
    1979 MG Midget
    1985 Sinclair C5
  • Tue, Apr 24 2012 10:18 In reply to
    • msb
      Mon, Nov 22 2010
    • burton on trent
    • Posts 92
     a proper roof cleaning kit should sort it out,renovo do a cleaner and sealing kit:)
  • Tue, Apr 24 2012 14:26 In reply to
    • BRGUK
      Sun, Nov 23 2008
    • Manchester
    • Posts 80
    I have just had a look on the auto glym website and it says you can cover with a hot towel and draw it out.
    I am just wondering if a steam cleaner might do the same thing?
    Do you think steam might damage the roof?
    Simon Taylor
    1979 MG Midget
    1985 Sinclair C5
  • Tue, Apr 24 2012 17:27 In reply to
    • msb
      Mon, Nov 22 2010
    • burton on trent
    • Posts 92
     steam shouldn't hurt it done carefully
