Geometry Day (£30) Sunday 29th July TIMES ADDED PLEASE CHECK!
Last post Mon, Aug 20 2012 18:31 by brianpng. 171 replies.
Page 1 of 12 (172 items) 1 2 3 4 5 Next > ... Last »
  • Sun, May 6 2012 17:42
    • kevallen
      Fri, Nov 14 2008
    • Norwich
    • Posts 1,146
    Please note times have been added beside your names below.
    Please ensure you arrive 30 minutes before the time on the plan.
    Back by Popular demand.
    Kieron at STS Tyre Pro in Wymondham has very kindly offered to run us another 4 Wheel Alignment Day with a difference but this time even better than before (if that's possible)
    Below is the link to the last event
    http://www.mx5oc.co.uk/forum/forums/t/38580.aspx?PageIndex=1
    It follows the same procedure as before but there are limited spaces and because its such great value you need to book early.
    Here is the format
    Location
    STS TYRE PROS
    Station Road
    Wymondham
    NR18 0JY
    Phone: 01953 603102
    Date - Sunday 29th July
    Hi All
    Just been to see my friendly tyre fitting guys and had a look at their latest high tech alignment gear, Wow they have spent a fortune on the latest gear.
    Anyway I asked if they would do a bit of a special for the Owners Club and he was very happy to get involved with this.
    So
    We need a minimum of 10 Cars (Maximum 20) and he is prepared to open up on a Sunday especially for us so that we can have full use of the facilities.
    They can do the 4 wheel alignment to factory settings or your own if you have your own specific requirements they are also prepared to swap wheels and tyres around if required and I am sure he will do something special if anybody needs new rubber.
    Plus
    1. Free nitrogen fill for all attending, That's right they will deflate you tyres and refill with Nitrogen for free ( this is worth a fiver on its own)
    2. They are prepared to offer fluid changing on the day for a nominal fee(£10 per item) (engine oil, diff oil, Gearbox oil and brake fluid) you will need to provide the oil and filters but they will do the rest.
    3. Bring your own brake pads and they will fit them again for a nominal fee (It's not worth getting your hands dirty for a tenner)
    4. If you want new tyres then Kieran is offering 35% off all tyres plus a fiver for fitting ( Pirelli P1 185/60 14 £38 + Vat or 195/50 15 £39.24 + Vat) He can get any make but needs to know in advance please.
    5. Tyre changing and wheel swapping
    6. Exhaust Fitting
    7. Free Tea and Coffee
    8. Plus of course the main reason for going the full 4 wheel Geometry setup (Camber, Cast and toe) for £30.00
    9. Last time they even did 3 suspension swaps on the day.
    Basically he has opened the workshop for us and us alone so please support this event.
    I have took some pictures below of the facilities.
    Waiting area with live viewing of the geometry set up.
    General workshop
    Geometry set up area.
    Hopefully the weather will allow us to do some runs to try out your new settings.
    Please let me know if you would like a slot and what you would like done.
    Kevin
    1. Steve K 11:30        Alignment Engine Oil and Tyres                                    MK3 Black
    2. GeoffB 10:30          Alignment       Oil Change, Gearbox Oil, Diff Oil          MK2 Icon
    3. Adam 12:00            Alignment        MK3 Grey
    5. Andy 16:30             Alignment        MK1 Mariner Blue
    6. Brian Thompson 13:30     Alignment, Oil Change, Gearbox Oil and Diff Oil.          ?
    7. Paul & Sue 13:00      Alignment        MK1 BRG
    8. Dan 14:00                  Alignment        MK2.5 Nevada
    9. Jamie Thompson 08:30     Alignment, Gearbox Oil, Diff Oil and Brake Fluid          MK1 Black
                                       Front Brake Pads, Rear Brake Pads and discs 4 new tyres
    10. Andy Millar 14:00  Alignment 14:30, Engine Oil                                Mk3  (flatcoat1000)
    11. Peter Lewis 15:00  Alignment        MK3 Ice Blue
    12. Colin 14:30            Alignment 16:00, Sway Bar Bushes, Steering Gaitors x 2          Mk1 Black
                                        and possible Tyres
    13. Rob 10:00             Suspension swap and Alignment 15:30  Gearbox & Diff oil     MK1 Silver
    14*. David 09:00         Engine oil and Gearbox oil only Front Drop links      MK3
    15.  Dave 10:00           Alignment                                 MK2
    16. Martin 09:30          Alignment                                Mk1 Silver
    17*. Paul 08:30 & 16:00  2 x  Engine Oil and Filter Changes only   MK1 Blue & Mk2.5 Blue
    18. Dean 12:30          Alignment                                  MK3 Copper Red
    19. Steve 16:30        Alignment 17:00 & Brake Fluid   MK1 Black
    20. Chris Waterman 17:30    Alignment                       MK1 Classic
    21. David R 09:00    Alignment                                   MK2.5 Blue
    22*. Peter 08:00       Braided hoses only                     MK1 White, Blue wheels,
    23. Paul & Trish 11:00   Alignment                              MK1 Blue
    24. Colin 08:00             Alignment                               MK1 BRG
    2001 Mazdaspeed & 1991 MK1 Lemon
  • Sun, May 6 2012 19:26 In reply to
    • MX5 Paul
      Wed, Dec 16 2009
    • Norwich Norfolk
    • Posts 300
    Re: Geometry Day (£30) Sunday 29th July 2012
     Not sure I need a Geometry check done, but Im sure I can up with something, will keep you posted as for what,  I have met Kieron and he is a top bloke, he really likes the MX5's and he is considering on getting himself one.
    Count me in.
    Paul
    1.8 VT Sport 2.5
    1.6 Eunos Mariner Blue
  • Sun, May 6 2012 19:45 In reply to
    I will be along again as well, nice venue and some top guys.
    Really blown away by the equipment and knowledge.
    Mx-5 Owners club - Norfolk Fives, Great Cars - Great Friends - Great fun
    Check out the Norfolk Fives web portal at: www.norfolkfives.co.uk
    It has direct links to our Forum, Facebook and Twitter pages, everything you need for fun in your Norfolk Five.
  • Mon, May 7 2012 12:37 In reply to
    • sjk
      Tue, Feb 28 2012
    • LAKENHEATH SUFFOLK
    • Posts 111
     Kevin
    Put me down for the 4 wheel alignment, may be interested in some tyres to will ring STS nearer the time if I don't find some sooner
    Steve K
    MK3 black 1.8 option pack 2006 (Ebony) Cobra Back box
  • Mon, May 7 2012 13:51 In reply to
    • GeoffB
      Thu, Jun 30 2011
    • Suffolk
    • Posts 46
     Hi Kevin.
    Will you add me for a slot please for the geometry set up and the oil change, engine, gearbox and dif.
    GeoffB
    2000 W Mk2 icon Art Vin Rouge Mica
  • Mon, May 7 2012 19:55 In reply to
    • kevallen
      Fri, Nov 14 2008
    • Norwich
    • Posts 1,146
    sjk:
     Kevin
    Steve K
    Hi Steve
    Got you on the list.
    If you can't wait for the tyres give Kieron a ring and explain you are booked on the day but can't wait for tyres and see what he can do them for.
    He is a great guy and I am sure will help if he can.
    Thank for supporting the event.
    Kevin
  • Mon, May 7 2012 19:57 In reply to
    • kevallen
      Fri, Nov 14 2008
    • Norwich
    • Posts 1,146
    GeoffB:
     Hi Kevin.
    Hi Geoff
    Got you on the list and thanks for your support.
    It's a great social day with lots of tyre kicking in the car park and I plan a couple of runs so you can try everything out before you leave.
    Good to have you on board.
    Kevin
  • Tue, May 8 2012 22:24 In reply to
    • mandie_d
      Sun, Apr 1 2012
    • Dereham
    • Posts 59
    Hi Kev,
    Book me in for Geometry set up and possible brake pad change.
    Mandie
    MK2 White RS
  • Tue, May 8 2012 23:16 In reply to
    Book me in for a geometry please. I'm fitting some 40mm lower springs in a week or two so I'll want it resetup after that.
    I might as well have the gearbox, diff and brake fluid changed at the same time.
    Colin
    1990 Red NA 1.6
  • Wed, May 9 2012 12:14 In reply to
    • kevallen
      Fri, Nov 14 2008
    • Norwich
    • Posts 1,146
    Betty_Swallocks:
    Colin
    Hi Colin
    Got you on the list, Seens how you came last time how about a bit of an endorsement as to what great value this day offers members.
    Any help is appreciated.
    Kevin
  • Wed, May 9 2012 12:16 In reply to
    • kevallen
      Fri, Nov 14 2008
    • Norwich
    • Posts 1,146
    mandie_d:
    Hi Kev,
    Mandie
    On the List Mandie, perhaps Paul could do a few hood changes on the day. LOL
  • Wed, May 9 2012 13:34 In reply to
    kevallen:
    Hi Colin
    Kevin
    More than happy to. They did a great job and made us feel very welcome with a non stop supply of coffee.
     The car felt great driving back and at 30 quid is a real bargain.
    1990 Red NA 1.6
  • Wed, May 9 2012 14:57 In reply to
    Hi All,
    I had this geometery done on my car only last week at Formula 1 in Peterborough, the front drivers side was slightly out. I had a long explaination about this new bit of kit that does the geometery via the computer and all 4 wheels will be perfectly in alignment. The car went on this brand new ramp and 10 mins later they produced a print out of all that was wrong, along with my front driverside wheel being out of alignment also the rear driverside camber angle needed adjustment, so all seemed well, NO!! After an hour or so the young lad started smashing at the rear camber adjust with a chisel and a 10lb hammer, I ran across and told him to stop and had a look at his handy work, he had managed to split along the camber adjust with his actions. I complained to the manager who seemed to think that this is the correct method of adjustment! (I of course will be taking this matter up with their head office due to the damage). Eventually I was given another print out that showed all was now in alignment and a bill was produced  for £127.00. I was shocked and asked why so much, apparently it's £17.50 per adjustment + Vat. After a long argument the manager made me an offer of £63.00 all in as no one had bothered to explain the price structure in advance, be warned and check first!
    My point to all of this is to say that at £30.00 it's an absolute bargain and I wish I had read about this beforehand.
    Brian.
  • Wed, May 9 2012 16:05 In reply to
    • kevallen
      Fri, Nov 14 2008
    • Norwich
    • Posts 1,146
    barneybear:
    Hi All,
    Brian.
    Thanks for the comments Brian, Sorry to hear about your bad experience.
    We ran a day like this back in February and it was a great success so it was nice to be asked back again. They managed 20 cars on the day which was a fantastic achivement and I think everybody left happy.
    Kevin
  • Wed, May 9 2012 18:45 In reply to
    • MX5 Paul
      Wed, Dec 16 2009
    • Norwich Norfolk
    • Posts 300
     Sorry to hear about your bad experience Brian, sounds like they paid for the gear but didn't  train their staff Sad I always ask fellow members for recomendations thus limits any problems later, hope all is now well.
    Perhaps you could pop along even just to check the guys out?? Maybe then use them at a later date.
    Paul
    1.8 VT Sport 2.5
