lowering my mx5, do VW coilovers fit a mk2
Last post Sun, Jul 1 2012 0:05 by youmitegetian. 4 replies.
Page 1 of 1 (5 items)
  • Sun, May 27 2012 21:04
    • youmitegetian
      Sun, May 27 2012
    • evesham worcestershire
    • Posts 13
    As the title suggests i want to lower my mx5, i have read somewhere that mk2 golf coilovers will fit, doe anyone know if theis is true? its just i can get some of those easily and virtually for free so if possible id like to use them. any help would be appreciated
    Mx5 1,8 1999 green
    A life with no risk is no life at all
  • Sun, May 27 2012 21:29 In reply to
    • AT
    • Posts 6,403
    Re: lowering my mx5, do VW coilovers fit a mk2
    Never heard of that. This picture of a Golf Mk1/2 setup (front macpherson strut) suggests not:
    Maybe the rears might "fit", but I wouldn't fit it. If you're on a budget, you're better off just cutting the springs; not really recommended, but people have done it, and lived to tell the tale.
  • Mon, May 28 2012 23:34 In reply to
    • youmitegetian
      Sun, May 27 2012
    • Posts 13
    I did consider cutting the springs, maybe 1 coil, how far have other people cut them and got away with?
    Mx5 1,8 1999 green
  • Mon, May 28 2012 23:52 In reply to
    • AT
    • Posts 6,403
    See
    http://forum.miata.net/vb/showthread.php?t=366408
    There are a ton of other threads on miata forum. I don't recommend cutting the springs, but its better than trying to fit VW suspension. Cheap lowering springs can be picked up for £70. That will be even better than cutting rusted out worn out springs. £70 is not much more than a tank of petrol.
  • Sun, Jul 1 2012 0:05 In reply to
    • youmitegetian
      Sun, May 27 2012
    • Posts 13
    Ok so i finaly got round to cutting the springs on my 5, suprisingly easy to do, i did them without having to take them off the car which saved loads of time, and due to the design of the springs they seat perfectly as i only cut 1 full coil off, this also means with the car lifted and the shock at full extention there is still compression on the spring.
    The car drives as it did before cutting, and in my opinion looks loads better
    Mx5 1,8 1999 green
