MK3 Radiator
Last post Fri, Jun 1 2012 0:13 by Rich M. 5 replies.
Page 1 of 1 (6 items)
  • Mon, May 28 2012 22:35
    • FIRE ONE
      Fri, Dec 10 2010
    • HITCHIN HERTS
    • Posts 39
    MK3 Radiator
      What sort of job is it to fit a rad on a mk3, i think one of my led lights wire has made mine leak. does the rad come out at top or bottomCry DAVE
    FIRE ONE
  • Tue, May 29 2012 10:43 In reply to
    Re: MK3 Radiator
    FIRE ONE:
    Um...what? How?
  • Thu, May 31 2012 10:21 In reply to
    • FIRE ONE
      Fri, Dec 10 2010
    • HITCHIN HERTS
    • Posts 39
    Re: MK3 Radiator
     havig fitted my led driving lights, i left a wire with a conector on the end  ( trying to find a power souce) it got into the fan and put some nice holes in my rad. Thinking
    FIRE ONE
  • Thu, May 31 2012 23:45 In reply to
    Re: MK3 Radiator
    Well, frankly I'm working blind here...best wait for someone who has done it to come along.
    However...rads are generally pretty easy on the whole. You've got to drain the system (one plug) and take off two hoses. The only variable is how easy it is to get it dismounted and out, which should be easy enough to tell by looking.
  • Thu, May 31 2012 23:46 In reply to
    Re: MK3 Radiator
    By the way, that's pretty harsh! A 10p connector has probably just done away with a good few hundred quid! Sad
  • Fri, Jun 1 2012 0:13 In reply to
    • Posts 1,523
    Re: MK3 Radiator
    Ouch! Well I'm afraid it looks a nightmare for what you'd expect to be a simple job. According to Haynes 61016 and Mazda manual, http://www.mellens.net/mazda/Mazda-Miata-2006-2007/cooling_system.pdf it reads more like taking the car off the rad than the rad out the car,
    it comes out the bottom along with the fan and shroud after,
    disconnect battery
    raise car
    remove under cover
    drain coolant
    remove battery and tray and cooling duct
    remove air filter housing
    remove pcm
    remove pcm cooling duct
    remove coolant reservoir
    disconnect rad fan
    disconnect upper and lower hoses
    remove power steering cooler line and air con condenser (do not disconnect hoses)
    remove upper and lower rad insulators
    Sad
