Radio cutting out intermittently...
Last post Fri, Jun 22 2012 15:38 by AT. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Jun 21 2012 19:43
    Bit of a pain, I've had an aftermarket HU for a few weeks, installed myself...recently the radio has started cutting out (audio/signal not HU power) when going over bumps, changing gear or engaging the handbrake...
    The USB/cd side of things works fine with no cutting out, so i don't think it's a speaker or power issue, more the radio signal being interupted.
    Before I go through the faff of removing the HU to check the aerial-in cable connection, is there anywhere else in the car I can check the aerial connections...
    Any ideas appreciated :)
    Mk2.5 Phoenix 1.6i
  • Fri, Jun 22 2012 15:38 In reply to
    • AT
    • Posts 6,402
    Re: Radio cutting out intermittently...
    The aerial has its own jack connection in the boot.
