A Lucky Escape!!
Last post Sun, Jul 1 2012 10:48 by MX Col. 10 replies.
MX Col
Tue, Jun 26 2012
- Posts 4
Hi All..... I'm a new user on the forum but just wanted to share this with you all to aviod anything similar happening to you.
My wife went to start our Mk 2 1999 car, when it just kept turning over and wouldn't fire up. Then the key symbol on the dash began to flash and quite soon the battery went flat. I wondered if it was an alarm/immobiliser fault, so disconnected the battery re-charged it still nothing!
So I had it recovered to my usual garage, who is a good general mechanic who has never let me down.. He then tried all that he could, a crankshaft sensor, disconnecting the cobra alarm, and checking the coding of the key/iginition, still the same and wouldn't start. Two seperate auto electricians looked at it and both concluded it was 'probably' the transponder/arial in the ignition or even maybe the ECU. My pal at the garage was scratching his head and after both electricians found nothing with the plug- inn diagnostics, the only option seemed to be the expensive trip to Mazda. But before he did this he decided to check the wiring and see where it took him. Well it took him towards the ECU, which if you didn't know as I didn't, is located under a metal plate in the passenger footwell. When he took the carpet up and plate off, the only thing missing was a surfboard!! it was all swimming in water, and the ECU was wet through. He took it all out gave it the hairdryer treatment and to my amazement it fired up straight away, and touch wood is still doing so. I then wondered why so set out to look. And it was those little nuisance drain holes again, or lack of as I found out! I rang a friend Peter from Mazmania, who explained where they should be, however I still couldn't see them so drilled a few on his advice. I don't know if the 2 in the hood would have any bearing on it too but they were also blocked, and once I found them behind the seatbelt fixings, a long screwdriver soon unblocked them. So as water now runs out of these holes I am hoping the problem is cured and the ECU doesn't have any lasting damage, I suppose time will tell. I just thought I'd share this with you in case it helps anybody who may experience the same problem.
Regards, Colin
Mazda-mender
- Pie land/NW England
- Posts 7,036
MX Col:I rang a friend Peter from Mazmania, who explained where they should be, however I still couldn't see them so drilled a few on his advice
What???
Please post up a pic and let us see what and where you have been told to drill?
If the drain holes were blocked then that is where he should have told you to look first,also the seals around the hood frame and windscreen header,which to be honest as a hood fitter is where he should have pointed you to check as a no brainer.
You have been very lucky,keep her dry
There is and should never be any need to drill holes in the roadster for drainage.
Please feel free to P.M me with any problems or questions. http://www.mx5oc.co.uk/forum/members/Mazda_2D00_mender.aspx http://www.mazdamenders.net/ http://www.autolinkuk.co.uk/ MADE BY MAZDA, MAINTAINED BY MAZDA MENDERS The online garage for those owners that like to play with spanners and different coloured grease. Mk 1.5 Eunos Roadster 1.6 1992 silverstone......Being fettled Mk 1 V.S II EUNOS 1.8 1993 black...fettled Mk 2.1/4 V.S ROADSTER 1.8 1999 black....fettled Mk 2 V.S ROADSTER 1.8 1999 white....being fettled for shows only
Terrano Kid
Thu, Jun 18 2009
- Shipley West Yorkshire
- Posts 52
After all that rain on sunday my wife noticed the passenger foot well was very wet never seen that before so wet. my drain hole was blocked would this have caused it to be so wet. ????? what side is the ECU on
Brian
1.6 Gearbox Manual Year 1999 Colour Racing Bronze Mica KN Typoon EBC Dimpled,groved,green stuff Pads sun roof.
Other Vehicle Nissan Terrano 4x4
Mazda-mender
- Posts 7,036
If the drain holes are blocked ,it will just over flow somewhere else, into the body tub,foot well and boot, it needs to go somewhere, and water will find its own route.
Terrano Kid:what side is the ECU on
Passenger side foot well buddy
Never forget that you also have drain holes at the jacking points for the sills because if the drain trays/tubes are blocked .it will find its way into the inner sills and stay there if they are blocked also =water, tin worm and rot you can not see.
Lazza
Tue, Sep 30 2008
- Wokingham
- Posts 47
Many years ago I had a MkIII Cortina that was a bit of a rust bucket so that the footwells both sides used to fill with rain-water. I "fixed" it by banging a screwdriver through the floor on both sides to let the water drain out. 6 months later the floor on both sides was falling through due to chronic rust, mostly around the holes I banged through! It didn't matter on that car as it cost me £100 and I didn't expect it to last as long as it did. I wouldn't dream of doing anything like that on any car I actually cared about! Did you at least put any rust inhibiter around the drill holes?
Lazza Red 2001 Mk2.5 1.8 Sport MP62 Supercharged + TDR Intercooler + Adaptronic + 550cc Injectors + 120mm Pulley RB Dual Exhaust + Larini Sport Mid-pipe + Larini Sport Cat MX5 Mk3 Seats + HD Deuce Rollbars + GAZ Gold Pro suspension
Jame5
Tue, Jun 19 2012
- Ireland
- Posts 142
hi noob here .. what about the ac drains
It's Not All About Big Power, Its About How Much Can Be Used
DanKent
Wed, Apr 22 2009
- Medway, Kent
- Posts 182
My drivers footwell gets very very wet if I park facing downhill in heavy rain. So far parking upwards prevents it. The holes behind by seatbelt towers are clear too.
1996 Mk1 1.8iS in Black & 2006 Mk3 2.0 Sport in Winning Blue 2010 Honda CR-Z GT Previously 2 x Mk1 Californias.
MX Col
Tue, Jun 26 2012
- Posts 4
Thanks for all those, and i'll try and put some pics on.. I've only drilled tiny holes in the sills where he told me the holes should be as I couldn't see them, as maybe they have been covered over?
Also you mention the rail/seal around the hood?? could somebody explain where these are, as I only found the 2 holes behind the seatbelts and unblocked those? I certainly dont want to go through that again.
Regards, Colin
MX Col
Tue, Jun 26 2012
- Posts 4
Thanks for all your help all....
Touch wood, still dry!!
Col
Page 1 of 1 (11 items)
