Crankshaft Pulley Bolt.
Last post Sat, Jan 12 2013 9:43 by mike b. 18 replies.
brines
Wed, Jun 20 2012
- Chatham Kent UK
- Posts 11
I'm in the middle of changing the cambelt on my "94 Eunos as its done 98k km and it should have been done at 90k. Have followed manual procedures and am at critical stage. Can anyone tell me how to remove the Crankshaft pulley bolt from the crankshaft nose. Unless I can do this everything done so far is for nothing. I've tried jarring it against the compression and heating it but to no avail. Any advice will be helpful as it's many years since I've done anything like this. Many thanks in advance.
Brines
Eunos Roadster E-NA8C-102099
taff eunos
- Riviera, South Wales
- Posts 4,395
Re: Crankshaft Pulley Bolt.
You either need a crankshaft locking tool (available to loan to club members) or you can lock the crank by threading some cord into No.1 cylinder as the piston is coming back up to TDC in the reverse direction to normal engine rotation. You need a 600mm breaker-bar and 6 point (impact) socket. Am not sure heating the bolt is a very good idea tbh.
If you were in S Wales I have a locking tool you could borrow....
Dr. Eunos
brines
Wed, Jun 20 2012
- Chatham Kent UK
- Posts 11
Many Thanks Dr Eunos,
Is reverse rotation anti clockwise when looking at the cranshaft bolt from the front? Unfortunately I'm in Chatham so I'm unable to take you up on your kind offer of a loan of your crankshaft locking tool. Is this a universal tool that I can hire or is it a special available through the trade?
Brines
Mazda-mender
- Pie land/NW England
- Posts 7,029
flying flea:
I'm in Chatham. PM me if you get stuck or need any help
Please speak to this dude as he is a member of the Mazda mender 5 emergency service and will be of help to you with being so close.
Please feel free to P.M me with any problems or questions. http://www.mx5oc.co.uk/forum/members/Mazda_2D00_mender.aspx http://www.mazdamenders.net/ http://www.autolinkuk.co.uk/ MADE BY MAZDA, MAINTAINED BY MAZDA MENDERS The online garage for those owners that like to play with spanners and different coloured grease. Mk 1.5 Eunos Roadster 1.6 1992 silverstone......Being fettled Mk 1 V.S II EUNOS 1.8 1993 black...fettled Mk 2.1/4 V.S ROADSTER 1.8 1999 black....fettled Mk 2 V.S ROADSTER 1.8 1999 white....being fettled for shows only
brines
Wed, Jun 20 2012
- Chatham Kent UK
- Posts 11
Thanks to everyone for their help, particularly flying flea who brought his wonderful Eunos round to show me what mine could be like given a lot of TLC. A wonderful forum and a great bunch of people. Such a help to a novice!!
RICKYWG
Thu, Nov 29 2012
- Gillingham, Dorset
- Posts 32
Hi, have this same problem removing the pulley bolt and I am in North Dorset. is there any one nearby who can help or where can I get the loan locking tool
RED 1992 Mk1 - Out and about - having fun
Geoff Walton
- Posts 11,081
RICKYWG:r where can I get the loan locking tool
email to technical@mx5oc.co.uk
Tue, Apr 1 2008
- Ely, Cambs
- Posts 3,846
Click this link or see page 64 of the December 2012 issue of Soft Top Hardtop.
Disclaimer Any work you do to your car is entirely your own responsibility. If in doubt, you should check technical advice with an independent , qualified person who has seen your car. The MX-5 Owners Club, its officers and forum contributors accept no responsibility for any damage caused to your person or property as a result of you following or not following the advice offered on this forum. roadsterrobbie.co.uk - mx5easternregion.co.uk - havemorefun.co.uk - merlotmotorsport.co.uk
brines
Wed, Jun 20 2012
- Chatham Kent UK
- Posts 11
Hi RickyWG
Spent a week entertaining myself trying to do the same thing last Autumn!! Eventually followed advice on the internet and used a 2ft lenght of scaffold pipe wedged against the floor of the garage (on the nearside-L/H). First short touch on the starter motor and it moved, next touch and it was loose. Sounds more drastic than it is!! Good Luck.
Mazda-mender
- Posts 7,029
Thats a good way if you have key wear, my problem with this without the right tools, is how did you torque it back up correct, and know that it is right.
RICKYWG
Thu, Nov 29 2012
- Posts 32
decided to borrow the OC special service tool for the job, i am not in any hurry so happy to wait for that.
Phil H
Mon, Nov 17 2008
- Dorset
- Posts 969
If someone could do a simple sketch with dimensions of the crank locking tool and scan and post on here it would be handy. Then it would be possible for owners to make a tool up. It seems to be just a round boss with the centre hole and 4 bolt holes with a stepped handle welded to it so would be easy to make.
Regards, Phil.
1991 "J" Ltd 1994 "V" Spec
