Inlet manafold removal MK1
Last post Tue, Jul 31 2012 14:37 by Jack. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Jul 30 2012 22:40
    • redmazda
      Fri, Nov 21 2008
    • south wales valleys
    • Posts 589
     hi all i did this job a few years ago on my last mx5 so i will be doing it again i hope just after some tips and tools needed for the job im going to renew all the collant hoses and get my cam cover and inlet manifold polised and airflow  just after the best way to remove the inlet manifold i will replace the gaskets also thanks
    Previous mk1 eunos 1.6 classic red
    Now own
    Mk1 UK 1.6 1990 classic red with F.S.H
    E90 330 D BMW
    Fiat 500 1.2sport
    Winner of Raleigh Burner BOTY 2012
  • Tue, Jul 31 2012 14:37 In reply to
    • Jack
      Fri, Aug 20 2010
    • Posts 189
    Re: Inlet manafold removal MK1
    I did this recently, and found the best option was the right size socket, and just about every imaginable combination of short, medium length and long extension bars, UJ driver and a very fine toothed ratchet.
    Make sure engine is completely cold, and remove the wiring around the manifold. I can't remember if you remove the fuel rail before or after, but I think doing it before will give you more space to get to things. Make sure you do not lose the two plastic jobbies that space the fuel rail off the manifold - I dropped one and it took ages to find because it isn't magnetic and doesn't make a noise when it goes. Also take photos of where all the hoses and wires run before you remove - it was something I'd not thought about and had to look it up to make sure that the connectors were all running the right way round so that they reach properly.
    Otherwise just take your time and it should work out - good lighting also helps to see what is going on while you try and get to the difficult ones underneath.
    Jack.
