Eunos V Spec - Fog Light?
Last post Sat, Aug 11 2012 23:08 by nottsmx5. 4 replies.
Page 1 of 1 (5 items)
  • Thu, Aug 9 2012 21:23
    • nottsmx5
      Sat, Mar 7 2009
    • Posts 59
     Hi ,
    I have just bought a roadster and I cannot see the fog light.
    The rear fog light on my UK MX5 was below the rear bumper. I can't seem to see it on the Eunos.
    Also on the left next to the steering wheel there are 3 blank switches, but below this there is a small switch, does anybody have any idea what this does!
    Thanks, Grant
  • Thu, Aug 9 2012 21:33 In reply to
    • DavesBRG5
      Sat, Nov 15 2008
    • Bedfordshire
    • Posts 2,396
    Re: Eunos V Spec - Fog Light?
     A Eunos wont have a rear fog lamp unless it`s been added. Have you checked to see if the reverse light or centre brake light have been converted to a fog lamp? That may be what the switch is for. The reverse light conversion is the most popular & looks much better than a big ugly bolt on lamp.
    1992 ROADSTER 1.6 Tanabe Sustec suspension, Cusco bracing, BBS Alloys, Momo Prototipo steering wheel, Mike Satur TT Hoops & Jass Performance interior bling.
  • Thu, Aug 9 2012 21:35 In reply to
    • Andrew Stott
      Fri, Dec 12 2008
    • Upper Swanmore
    • Posts 203
    Hi Grant,
    Turn the lights on, switch on the mystery switch, walk round to the back of the car and see if there's a fog light on.  Some cars have the r/h reverse light wired as the foglight, and some have the centre brake light.
    Andrew,
    www.autolinkuk.co.uk (T)
  • Thu, Aug 9 2012 21:37 In reply to
    • Dave D
      Fri, Mar 16 2012
    • Dover, Kent
    • Posts 111
    Maybe your offside reversing light has been converted to rear fog, quite a common mod. Mine's been done like this.
    Also I would suggest that the switch you have found is for this. Have a look at the offside reversing light, it will probably have a red film on it. If it doesn't it could still have been converted by using a red bulb.
    Try switching the switch under the dashboard, with the lights on (should only need to be on side lights). Does the switch illuminate? Chech the reversing light, is it lit?
    Mk1 Roadster, 1.6 1989, imported 2000
  • Sat, Aug 11 2012 23:08 In reply to
    • nottsmx5
      Sat, Mar 7 2009
    • Posts 59
     Thanks, tried the swtich the light on the boot lid appears to be the fog light!
