EASY Introduction to Coil Over Height Adjustment Someone!!!?
Last post Tue, Oct 9 2012 16:09 by markawinward@hotmail.com. 3 replies.
Page 1 of 1 (4 items)
  • Sat, Sep 8 2012 1:34
     Right. I've just purchased a lovely K-Reg Eunos Mk1 V-Spec, which the previous owner has a a set of Tein Coilovers fitted.Don't ask me which kind, they're covered in road dirt etc,.. Now I'd like to take advantage of the hieght adjustment available as it looks like it sits up a little at the front and I'd like to firm up the handling as I don't mind a more firmer ride. I know there's a c-Spannner needed,. but..... Which ring turns first,.what do I unlock , which direction for lowering i.e. anti clockwise or clockwise,.? They are I think these,.. http://www.tein.co.uk/product/street_advance.html .  I know a good height is about 325mm front and 336 rear (recommended on Flyin Miata).  Presumably I should remove the wheels first to gain access, do I need to jack up?. Also if the damping is adjustable where would i find this? I know with AGX it's a turn knob on the side,.
    Any help would be great,
  • Sat, Sep 8 2012 10:10 In reply to
    • mikeh492
      Sat, Dec 5 2009
    • bristol
    • Posts 118
    Re: EASY Introduction to Coil Over Height Adjustment Someone!!!?
    the lower of the two rings is the locknut and the top one is the spring platform
    i think the damping adjustment (if fitted) is on the top of the damper piston so would be accesable from engine bay on tein shocks
    Mk1 UK MX5 1996 BRG
    track car with the following mods:
    Poly bushes all round, EBC Greenstuff Pads, EBC grooved & dimpled discs, Stainless braided brake hose, Front & rear strut braces, GAZ gold coilover kit, stainless decat pipe, k&n induction kit, TR lane roll bar
    alloy radiator, remote oil filter kit with extra oil cooler, cobra bucket seat with 4point harness 6speed gearbox with T2 torsen diff yellowstuff pads on front
    mk1 eunos as daily driver
    ebc grroved and dimpled discs, grrenstuuf rear and yellow stuff front pads, braided brake hoses, gaz gold pro coilovers
  • Sat, Sep 8 2012 16:07 In reply to
    • AT
    • Posts 6,383
    You are going to need two c-spanners; either get hold of new spanners from Tein, or get adjustable hook spanners (Cromwell, Draper etc). Be warned; not all generic fixed c-spanners will fit properly. And, the thickness of adjustable spanners means they are awkward to use. And don't be tempted to drift the rings; you will just mash up the notches. The Tein threads are frequently rusted, so expect some cursing as you free the locking ring and spring seat ring. You will want to release the locking ring by turning it counter-clockwise; the spring perch will be corroded and sticking to it, and so will want to turn as well; get a spanner on it to stop it turning.
  • Tue, Oct 9 2012 16:09 In reply to
    Thanks for your help. I found out previous owner has put Koni on Driver's side and Tein on passenger side!
