Clutch Squeak....
Last post Thu, Feb 23 2012 18:04 by Little bob. 22 replies.
Tartiflette
Sat, Nov 22 2008
- Scunthorpe
- Posts 23
Hi all,
For the last couple of months my clutch has started squeaking on pressing it in and out.
I wondered if it was just a case of something needing oiling or could it be a bigger problem?
Any ideas welcomed???
Mk 2 1.6 2000 California
Tartiflette
Sat, Nov 22 2008
- Scunthorpe
- Posts 23
01mx5:
Is it a loud squeak, and where is it coming from?
Hiya,
It is quite loud and very annoying! My dad said he could hear it when I was parked on his drive from outside the car...
JimSuperSix
Sat, Nov 15 2008
- Posts 144
Assuming the mk2 clutch is the same as the mk1, you could try greasing the end of the actuator rod where it pivots on the clutch arm - if you look down onto the bellhousing (on the drivers side on a mk1, under the inlet manifold) you should see the clutch slave cylinder with a small metal rod that pushes on the end of the clutch arm. This can dry out and be squeaky. Work some grease into the pivot point at the end (where the rod touches the clutch arm) and see if that helps.
IIRC you should be able to reach under the car and apply the grease quite easily with it on the ground, no need to jack it up.
1992 mk1 Eunos Roadster
Crystalblue
Sat, Aug 6 2011
- Berrow, Somerset
- Posts 29
I have this clutch squeek and will try this quick fix tomorrow. I do however have two questions.
1) Do I need a special type of lubricant.
2) As I have no mechanical knowledge I may not be able to find this cylinder or may just chicken out. If I leave this squeeking what damage will it eventually do?
2001 Crystal Blue 1.8 Mk 2.5 Member of the Blue Brigade.
Geoff Peace
- Ashton-in-Makerfield Lancs.
- Posts 553
The lubricant for the inside of the slave cylinder should be rubber grease, mineral oil or grease should not come into contact with hydraulic seals. At the other end if you push the tail of the arm into the cylinder a little way you will be able to grease the arm with any good quality mineral grease. Castrol LM or molygrease for example.
Regards Geoff Peace.
2004. Mk.2.5 1600c.c. in radiant ebony location Ashton-in Makerfield, Lancs. Fide sed cui vide
Geoff Walton
- Posts 9,983
There's a how to here, the squeeky bit is towards the end. As Geoff says, do not use ordinary lube WD40 anything that isn't suitable for use on hydraulic seals.They will perish and the clutch slave will expire.
Cure the squeek
Rich M
- Notts
- Posts 613
Hi Geoff(s)!
A few of us have raised the issue of the correct grease and the FAQ article should be updated if you are able.
The grease for the slave cylinder end of the pushrod must be brake rubber grease (castor oil based, usually red for identification, from parts stores and motor factors) or silicone grease (can be found at electrical retailers such as Maplin). These do not harm rubber unlike regular mineral oil greases. An easy source for small quantities is eBay.
The grease for the other end should be high melting point type to prevent it migrating to the slave rubbers with heat. A dab of regular HMP lithium or moly based grease will be fine.
2005 MX5 Mk3 Launch Edition Velocity Red 2 litre Sport 6 speed LSD 30K miles
Geoff Walton
- Posts 9,983
Rich M:The grease for the slave cylinder end of the pushrod must be brake rubber grease (castor oil based, usually red for identification, from parts stores and motor factors) or silicone grease (can be found at electrical retailers such as Maplin). These do not harm rubber unlike regular mineral oil greases. An easy source for small quantities is eBay.
The Mazda workshop manual doesn't mention any grease on the inner end of the pushrod. However through experience I know that a dab of white lithium grease works well as does, I imagine the red rubber grease. At the operating fork end the manual calls for Moly grease. I use Moly and white lithium
I'll put some new stuff in the faq
Rich M
- Notts
- Posts 613
Geoff Walton:
Hi Geoff,
The FAQ now says, "Before bolting the new cylinder to the car, pull out the actuating rod from the rubber bellows and apply a blob of Lithium white grease, or red rubber grease to the inner end. A blob of any good Moly grease on the other end will ease the operation of the clutch to both ends."
It should say "Silicone" and not "Lithium white". It is important to get it right for those that don't know not to use mineral oil grease on brake and clutch rubber parts.
Geoff Walton
- Posts 9,983
Rich M:It should say "Silicone" and not "Lithium white". It is important to get it right for those that don't know not to use mineral oil grease on brake and clutch rubber parts.
Hi Rich, I'll add silicone, but I know that Lithium white is very suitable for this application, I'll add something about mineral greases
Rich M
- Notts
- Posts 613
Geoff Walton:
Thanks Geoff, you may have been careful to apply it only to the metal parts of the pushrod and piston and none has migrated to the cylinder bore. The thought of someone pulling back the boot and giving it a blast from an aerosol of mineral grease is not good .
