Want to clean cam cover and inlet manifold - any advice?
Last post Sat, Jan 28 2012 0:13 by taff eunos. 19 replies.
baftacat
Fri, Dec 12 2008
- Reading
- Posts 911
Hi,
I want to clean up my cam cover, inlet manifold etc. I don't want them shiny, just really clean.
Any ideas as to best way forward? I tried a small patch with Autglym Metal Polish and it look better, but not like new.
91 Eunos 1.6 manual V-Spec with a few mods.
Pollyanna
- Northallerton, North Yorkshire
- Posts 3,207
Re: Want to clean cam cover and inlet manifold - any advice?
baftacat:
There is a liquid specifically for cleaning aluminium castings that is extremely good when used with a STAINLESS STEEL wire brush. I can't remember what it is called but will find out tomorrow and let you know. Do not use an ordinary steel wire brush.
Pollyanna
- Posts 3,207
pollyana:There is a liquid specifically for cleaning aluminium castings that is extremely good when used with a STAINLESS STEEL wire brush. I can't remember what it is called but will find out tomorrow and let you know. Do not use an ordinary steel wire brush
Sorry baftacat, I have been so busy cleaning and polishing my car today I completley forgot about the cleaner. I will try and find out tomorrow, have made a note for myself.
redmazda
Fri, Nov 21 2008
- south wales valleys
- Posts 590
i started doing mine with wet and dry to take dirty surface off then wire drill piece and then autosol looked good until i seen another one that had been taken off and polished so then i went to town fuel rail off new gasket and inlet manifold seals new coolant oil change while inlet manifold was off cleaned injecters new fuel hoses ect now it looks good photo dosent do it justise but still you can see it looks shiny
<a href="http://s704.photobucket.com/albums/ww41/redmazda_2009/?action=view¤t=DSC00192-1.jpg" target="_blank"><img src="http://i704.photobucket.com/albums/ww41/redmazda_2009/DSC00192-1.jpg" border="0" alt="inlet camcover airflow polished"></a>
Previous mk1 eunos 1.6 classic red Now own Mk1 UK 1.6 1990 classic red with F.S.H E90 330 D BMW Fiat 500 1.2sport Royal Enfield Bullet 350cc Fun Winner of Raleigh Burner BOTY 2012
Miles
Thu, Oct 23 2008
- Posts 387
Those green pan scourers you get in tesco for about 40p
Lord Protector Hemel Massive We're the people your committee warned you about.
Locke-alike
Tue, Nov 11 2008
- saddleworth
- Posts 1,009
paint it with silver smoothrite.
and you can do other parts whilst your there as well
 Max5 Mk3 race car 42 sponsored by http://www.brynhilton.co.uk/ www.masbars.co.uk
Pollyanna
- Posts 3,207
On another forum someone suggested using Coca Cola. Might be worth a try as it's supposed to bring copper pennies up like new.
Pollyanna
- Posts 3,207
pollyana:Sorry baftacat, I have been so busy cleaning and polishing my car today I completley forgot about the cleaner. I will try and find out tomorrow, have made a note for myself
The stuff I borrowed was called Alo Cure, but can't find out where to buy it from.
Pollyanna
- Posts 3,207
baftacat
Fri, Dec 12 2008
- Reading
- Posts 911
I will get some alu-cure. Thanks for the pointer.
I did try coca-cola. I drunk 6 cans of it and the engine looks no better!! (should I add barcardi?!).
Thanks for your help everybody. Great advice as usual.
-halli-
Thu, Oct 23 2008
- Alnwick, Northumberland
- Posts 595
I used WD40 and a pan scouring sponge. Came up very nicely and was degreased well for painting.
j-specmx
- Posts 3
Meguiars now do a engine de-greaser this will clean the engine and the bay to a good standard, without polishing and without requiring much effort.
see www.meguiars.co.uk for more info and prices. hope this helps. james.
Ron Hardie
Sun, Feb 1 2009
- Bristol
- Posts 40
Unfortunatly there is only one way to do this and it's hard work but worth it - take the cover off and on a solid bench or good work surface remove all the rough casting surface with wet and dry ,start with coarse grit and work down to really fine ,then you must buy two polishing mops and polishing wax - the black stuff (one is abrasive and the other shines the surface ) the surface must be really smooth ,once polished then and only then finish it off with solvol autsol - fill the indented lettering with red heatproof paint and you're done ,that is until you do the inlet as well !I learnt how to this with British Aerospace when we had an aircraft industry - we polished all the interior cabin fittings and they looked like chrome ! it looks great but is really hard work ,took me a week of evenings i(n the winter) but well worth it ,I'll send you photos if you want them
Ron Hardie MX5 Mk1 classic Red lowered ,vented discs,s/s exhaust,strut braces,K&N,new hood,leather seats ,and too much more to mention !
Pollyanna
- Posts 3,207
Ron Hardie:
This is what he said...".I want to clean up my cam cover, inlet manifold etc. I don't want them shiny, just really clean"
