Sand blasting
Last post Sun, Feb 28 2010 10:56 by 5UMO. 16 replies.
Page 1 of 2 (17 items) 1 2 Next >
  • Thu, Jul 30 2009 8:08
    • 5UMO
      Tue, Nov 18 2008
    • WICKFORD
    • Posts 707
    Sand blasting
     Hi,
    can anyone recommend person/company to do some sand blasting in our area ?
    thanks
    5UMO
    MK1 1.8is 1997 BRG
    MK2.5 sport 2001 Supreme Blue
    Member of the Blue brigade
  • Thu, Jul 30 2009 9:07 In reply to
    • MX-Drew
    • Canvey, Essex
    • Posts 1,047
    Re: Sand blasting
     I have a sand blaster, what is it you need to blast?
    If it's broken, repair and improve it. If it an't broken, just improve it.
    Mk2.5 1.8 2004 Strato Blue.
    Coldside MP62 supercharger & Air Con & Eibach Lowering Springs (all fitted myself).
    bastienw said "Je reste bouche bée par la NB à compresseur !!!!" Translated "I remain stunned by the compressor NB!!"
  • Thu, Jul 30 2009 19:55 In reply to
    • 5UMO
      Tue, Nov 18 2008
    • WICKFORD
    • Posts 707
    Re: Sand blasting
     I've purchased a cam cover and was told it will need sand blasting before i can get it powder coated,i thought it would only need degreasing but was told by the powder coaters that it would be a better finnish when blasted.
    5UMO
    MK1 1.8is 1997 BRG
  • Fri, Jul 31 2009 9:23 In reply to
    • niggle
      Fri, May 29 2009
    • Posts 2,651
    • Moderator
    Re: Sand blasting
    Sand blasting will probably leave a rough "cast" finish. If you want your powder coated cam cover to have a smooth, shiny finish then bead blasting might be preferable.
    Many powder coating workshops will have their own blast cleaning facilities (it is an essential preparation stage for many powder coating operations) so try and find one that does.
  • Fri, Jul 31 2009 22:52 In reply to
    • 5UMO
      Tue, Nov 18 2008
    • WICKFORD
    • Posts 707
    Re: Sand blasting
     I thought there were different grades of blasting or is this not true
    5UMO
    MK1 1.8is 1997 BRG
  • Sat, Aug 1 2009 1:06 In reply to
    • niggle
      Fri, May 29 2009
    • Posts 2,651
    • Moderator
    Re: Sand blasting
    5UMO:
    It is indeed true. There are also different types of blasting media. Media such as sand, grit and aluminium oxide tend to be "sharp" and leave a highly textured finish, especially on relatively soft materials such as aluminium alloys. Glass bead blasting leaves a finer finish that forms an ideal surface for priming and powder coating. AFAIK, alloy wheel refurbishers tend to use bead blasting rather than sand/grit blasting.
  • Sat, Aug 1 2009 17:59 In reply to
    • 5UMO
      Tue, Nov 18 2008
    • WICKFORD
    • Posts 707
    Re: Sand blasting
     So should i be asking them to bead blast it, it's not in bad condition just a bit greasy.
    5UMO
    MK1 1.8is 1997 BRG
  • Mon, Aug 3 2009 11:00 In reply to
    • niggle
      Fri, May 29 2009
    • Posts 2,651
    • Moderator
    Re: Sand blasting
    Depends on what type of finish you require and how thick the powder coat finish will be.
    If you want a coloured, textured finish then I should imagine that a thorough chemical clean of the casting and then a relatively thin layer of powder coat might suffice.
    If you want a smooth finish then it might be possible to hide the original rough cast finish with one or more thicker coats of powder.
    Some kind of blasting would probably be a good idea to remove any build up of oxidation on the casting first. I would also imagine that a smoother, blasted surface would be easier to clean and degrease and is more likely to achieve a smooth powder coated finish.
    The best bet is to tell the powder coater what kind of finish you require and let them recommend the processes that they would need to perform to achieve the results that you are looking for.
  • Mon, Aug 3 2009 22:18 In reply to
    • 5UMO
      Tue, Nov 18 2008
    • WICKFORD
    • Posts 707
    Re: Sand blasting
     Hi Niggle
                   Thanks for the info it's with the sand blaster today,i will let you know the results once it's been powder coated,
                    i'm hoping for a smooth finnish.
    5UMO
    MK1 1.8is 1997 BRG
  • Fri, Aug 7 2009 10:01 In reply to
    • Pollyanna
    • Northallerton, North Yorkshire
    • Posts 3,156
    Re: Sand blasting
    5UMO:
     This will be interesting as the cover is a rough cast finish and I would have thought that to get a good smooth finish, the cam cover should be "sanded" down with wet & dry paper first.  Remember that the final coat of any paint is dependent on the previous preparations.  Will be pleased to read your comments when you get it back and a picture would be nice too.
  • Fri, Aug 7 2009 10:18 In reply to
    • Posts 9,383
    Re: Sand blasting
    A few pics of my powder coated cam cover. The powder coater bead blasted the whole cover, as he didn't trust others to do the job properlt [he didn't charge for this, it was in the price]
    Also make sure that you remove the thin cover plates on the underside as the heat of the curing process will destroy the sealant. Another thing to bear in mind, if you have an after market oil filler cap you need to make sure that the thread in the top of the cam cover doesn't get coated, I learned that one through experienceEmbarrassed
    Before
    After
    Showing the plates on the underside
    hth---
  • Fri, Aug 7 2009 22:43 In reply to
    • 5UMO
      Tue, Nov 18 2008
    • WICKFORD
    • Posts 707
    Re: Sand blasting
     Hi Geoff,
                   What is the thin cover plates on the underside,and also should i leave the gasket in place so that the paint doesn't cover it,the company doing the coating said that they would tape and cover what was needed but i will check with them what you have said about the oil filler.
    What i didn't understand and i did double check with them is that they wanted it blasted, i thought it would just have to be degeased.
    I will post some pictures once it's finished.
    Geoff did you have the underside of yours cleaned.
    5UMO
    MK1 1.8is 1997 BRG
  • Sat, Aug 8 2009 2:18 In reply to
    • Posts 9,383
    Re: Sand blasting
    5UMO:
    The plates form an air duct for the PCV system.
    Remove all gaskets and sealant
    5UMO:
    De greasing is only part of the process, bead blasting ensures an even key for the powder.
    5UMO:
    No, just washed it down in a cleaning bath---
  • Sat, Feb 27 2010 17:50 In reply to
    • 5UMO
      Tue, Nov 18 2008
    • WICKFORD
    • Posts 707
    Re: Sand blasting
     Pictures of  powder coated cam cover, not yet got round to finnishing the lettering, i was thinking of painting them yellow.... what do you think ???
    5UMO
    MK1 1.8is 1997 BRG
  • Sat, Feb 27 2010 21:36 In reply to
    • Pollyanna
    • Posts 3,156
    Re: Sand blasting
    5UMO:
    Why not and you could repaint the engine strut bar to match it, colourwise.
