Paragraph spacing
Last post Mon, Nov 24 2008 22:07 by Raydar27. 7 replies.
Page 1 of 1 (8 items)
  • Sun, Nov 23 2008 19:41
    • Raydar27
    • Warwickshire - West Midlands
    • Posts 211
    • Area Co-ordinator
    Paragraph spacing
    All of my posts so far seem to suffer from this and i don't know how to change it or if i have problem on my account. When i type, all the sentence appear together and i cannot space out my text using the return key to create a new paragraph. What have i done? how do i fix it?
    Steve: Area Co-ordinator for the West Midlands area
    West Midlands - Phoenix Fives - Theres more to us than a monthly meet.
  • Mon, Nov 24 2008 0:42 In reply to
    Re: Paragraph spacing
     Same here, also smilies/ message font editing bar doesn't always appear when I Quick reply to topic.Confused
    Has done this time though.Tongue Tied
  • Mon, Nov 24 2008 8:59 In reply to
    • martin
      Tue, Apr 1 2008
    • suffolk
    • Posts 5,103
    • Committee
    What browsers are you using ?
    How have you got the content editor set in your profiles. ?  It can be plain standard or advanced with more buttons, that may make a difference.  It looks like everytime you make a post for first time in a visit it takes a second or two to load up the button icons, maybe your pc or browser is not completing that fully for some reason.
    Paragraph spacing is odd as a return will space down two line but shift return will just go down one. Try shift return and see what that does.
    martin
    Best Kept Mk2 - Spring Rally 2012 - National Rally 2012
    Club Management Team - Communications - Area Coordinator Liaison
    havemorefun.co.uk | merlotmotorsport.co.uk | facebook.com/mx5oc | twitter.com/mx5oc
  • Mon, Nov 24 2008 10:32 In reply to
    • Raydar27
    • Posts 211
    • Area Co-ordinator
    Well when im at work i use IE and same for home. But the tools dont appear all the time at home but are fine here at work. Tried return now:
    Tried shift return now:
    did it work?
  • Mon, Nov 24 2008 10:33 In reply to
    • Raydar27
    • Posts 211
    • Area Co-ordinator
    Answer - fine at work but trouble at home Tongue Tied
  • Mon, Nov 24 2008 21:41 In reply to
    • -halli-.
      Thu, Oct 23 2008
    • Posts 137
    Raydar27:
    Can you do a screen dump and post the picture up here so we can see what you mean?
    Doesn't the term "screen dump" paint a disturbing picture when you think about it? Wink
    -halli- THIS IS MY GUEST ACCOUNT - I WON'T BE USING THE OC ACCOUNT UNTIL THE PRIVACY ISSUE IS RESOLVED ON THIS FORUM
    '90 Eunos Roadster 1.6 - SilverStone (The daily commute)
  • Mon, Nov 24 2008 22:05 In reply to
    • Raydar27
    • Posts 211
    • Area Co-ordinator
    if i type a load of bable like this ( excuse the repeating words): Test test test test test test test test test test Test test test test test test test test test test Test test test test test test test test test test Test test test test test test test test test test Test test test test test test test test test test Test test test test test test test test test test
     Paragraph ^ (return key) it will come out as one block of text and not the two defined paragraphs as per the screen shot
  • Mon, Nov 24 2008 22:07 In reply to
    • Raydar27
    • Posts 211
    • Area Co-ordinator
    ok.....it worked Tongue Tied who fixed it??
    if you look here : http://mx5oc.co.uk/forum/forums/t/888.aspx my post got compressed .. no line spacing etc
